mikegoetz
- Northern Kentucky
We are experiencing alot of vibration and humming on our main switchgear. I installed a new 4,000 amp Siemens switchgear with a 2500 amp main breaker. The switchgear contains (5) 600 amp breakers that feed (2) VFD's and (3) soft starters for compressors. The compressors are 250 and 300 horsepower motors @ 3 phase, 480 volts. The two VFD's are in bypass mode on the controllers, so the motors are starting up @ 60 hertz off the breakers. The breakers are hotter than normal and are reading a thermal temperature of a 115 degree's. The refrigeration company said when the compressors run off the VFD's at low frequency startup they are experiencing to much vibration on the compressor screws, so for right now they are over the line startup off the breakers. The voltage on the switchgear is fluctuating between 462 to 471 volts a.c. and the amperage on the meter is reading 1200 to 1300 amps. on each phase. The compressors are alternating startup off the refrigeration system. When one of the compressors starts up the gear surges and vibrates heavily. Once the compressors are fully started the gear vibrates and humms like a transformer. When I turn the compressors off, the vibrating goes away. There are other breakers in the switchgear that feed evaporator panels, lights, and motors, but when they are all on and the compressors are turned off we aren't experiencing any vibration. The vibration in the switchgear is in the first (3) sections of gear and not in the last (4) sections were the breakers are that feed the equipment. The 3rd section of gear is where the bussing splits with Kirk-key breakers. We are scheduling a shutdown to re-torque all connections in the gear and starters. Does anyone know what else might be the problem causing the switchgear to do this?
