electrical question
goatman
New member
Hello,i need some help.I want to install a 70amp subpanel in my detached garage,and i want to bring it from my main panel.I want to install a 70amp double pole breaker in the main to feed the subpanel.The main is a 30 space 150amp panel and there are 6-15amp...7-20amp...3-30amp...1-40amp...and 1-50amp breakers there now. Do i have enough left to put in a 70amp.I plan on using #4/3 with a grounding rod at the subpanel.It's about a 60ft.run.
dereckbc
Plano, TX
Re: electrical question
Goatman, your electrical contractor will be able to help you. This site is for electrical professionals, and it would not be appropiate for us to answer DIY questions. Good Luck.
