Electrical Range Calculation
tacomafc
Please help me make sure this calculation is correct for a 12.9 KW range.
12.9 KW-12.0KW= .9 KW
.9KW x 5%=.o45% or 100.045%
100.045% x 8kw= 8.0036kw
8.0036kw rounds down to 8KW or 8000 W/240V = 33.3 amps
wire size # 8 thhn awg.
breaker 40amp
Thank you
bcorbin
I'm confused where you are getting these rounding schemes. Ranges are resistive loads, which typically means their rating is going to be their fully-loaded amperage. This would be 53.75 A, as Shockin said. Even if you use a 70A breaker (53.75*1.25 rounded up, but consult your range manufacturer's specs for requirements), you're gonna need more than #8's.
jwelectric
North Carolina
  • Over 12 kW through 27 kW ranges all of same rating. For ranges individually rated more than 12 kW but not more than 27 kW, the maximum demand in Column C shall be increased 5 percent for each additional kilowatt of rating or major fraction thereof by which the rating of individual ranges exceeds 12 kW.
12.9 KW-12.0KW= .9 KW or 1
1 X 5% = 5%
8 X 105% = 8.4
8400/ 240 = 35
210.19(A) (3) Household Ranges and Cooking Appliances. Branch-circuit conductors supplying household ranges, wall-mounted ovens, counter-mounted cooking units, and other household cooking appliances shall have an ampacity not less than the rating of the branch circuit and not less than the maximum load to be served. For ranges of 8? kW or more rating, the minimum branch-circuit rating shall be 40 amperes.
bcorbin
Once again, the code fails us. If you breaker this circuit at 40 amps, it's going to nuisance trip a lot.
bcorbin
Well, I guess I'm going to have to take my college-boy self back to the books and figure out why not. I love it when I find out everything I've been taught is not true.
roger
Fl
Retired Electrician
Bcorbin, If you were to put a recording meter on this range for a year you would probably never see it get close to 40 amps even including the heavy Thanksgiving and Christmas cooking days. :)
Roger
iwire
Massachusetts
As Roger pointed out the rating and what it really uses are different issues.
UL, the manufacturers and the NEC are all on the same page (most times;)).
Sure I agree with you that if the unit actually used 53 amps for more than a few minutes the breaker would trip.
However it is very unlikely that will ever happen.
Maybe I will put an amp clamp on my range and see what I can max it out at. :)
roger
Fl
Retired Electrician
Shockin, I shouldn't be answering for Mike, but I will anyways, :D Hope you don't mind Mike. ;)
These words are the answer to you question " the maximum demand in Column C" The maximum demand for one range is 8 kw.
Roger
jwelectric
North Carolina
shockin said:
Jw - why wouldn't it be 12kw x 105%? I don't see why you get to go back down to 8 kw at that step.
This range falls in to this category
I found the ?8kw? from Column C
.9 is a major fraction as outlined in 220.5(B)
jwelectric
North Carolina
Roger
Thank you Roger I was a little slow in gathering my info
Edited to add
didn't see page two Imust be getting old
bcorbin
I guess I'm just of the mentality "the best value to the customer." A 40A breaker is going to trip at 32A. So....in order to save the customer an extra 50 dollars in materials, let's hamstring his 12.9kW range to only being able to put out 7.7kW (five hand-held hair dryers)? If you're going to "el cheapo" him on the circuit, tell him to save his money and buy a cheaper, smaller range.
jwelectric
North Carolina
What size circuit is recommended by the manufacture of the range?
This can be found in the owner?s manual.
I have been researching this for the past couple of months by looking at every range I come in contact with.
I have yet to find one that requires more than a 50 amp circuit with most of them saying min. 40 max. 50 amp.
I am hoping to find one that requires a circuit of more than 50 amperes before I die.
Now based on your post I think we all should send a letter to these manufactures and express our opinion that the circuit is not large enough.
bcorbin
Well....if the manufacturer is advertising his product as a 12.9kW range when, following his own recommendations, will only deliver 7.7kW, maybe you're right.
haskindm
Maryland
bcorbin,
Why would a 40 amp breaker trip at 32 amps? Do not be confused about continuous loads being limited to 80% of a circuit breakers ampacity. A range is NOT a continuous load. A circuit breaker will carry its rated amperage at its rated ambient temperature indefinitely. In fact it will carry an amperage well above its rated amperage for a long time. That is why we need an effective ground fault return path; so that in the event of a fault the circuit breaker will see an amperage of many times its rating and trip quickly. It would be VERY difficult to trip a 40-amp breaker from the load you could generate with a range rated 12.9KW. Perhaps possible, but not likely in normal use.
roger
Fl
Retired Electrician
Bcorbin, why do you think any 40 amps breaker will trip at 32 amps.
We are only allowed to load a breaker to 80% for a continuous load, but a breaker will not trip at 80%, it probably wouldn't trip a little over 100%.
As far as the continuous load is concerned, as long as it is interupted every 179 minutes or less, we don't have to concern ourselfs with it.
Roger
roger
Fl
Retired Electrician
Ooops, I appologize Haskindm, I was typing while you were posting.
Roger
