I don't see any reason for concern with this, just two pipes running side by side. This may be a plumbing issue if any but I even doubt that. A metering room may be a different story. Try a plumbing inspector if you EI can't help.
Yes, check your major building codes, Example - IBC, or your local favorite and its usually spec'd in new construction to maintain a minimum of 2" between other services
