Matt Chance
New member
We manufacture and install a demountable interior partition system (Superwall / Raco). Our Market has been in the Carolinas for approximately the last 25 years and have had no issues. We have expanded into the Virginia Market and have run into the following issue and need some advice. Briefly, the wall system is installed complete and then the rough in occurs after the installation. Typically a "renovation box" or "cut in box" is used to facilitate rough in and it attaches to rigid conduit or flex that is brought into the stud cavity from the top of the wall. The issue we have is the inspections department claims that the box has to be secured within 12" of the box per the NEC. The problem is that this can't be done because the wall system is complete prior to the rough in. What i am looking for is a name of someone to talk to, a testing agency or any other resource that could help. What i think i need is an engineering judgement from someone with national jurisdiction that will generate a written waiver. Please forward any ideas you might have. Thank you!
