Here is the setup- 200 amp sevice, panel is back to back with meter. I am using a 2 inch nipple between the meter and panel. On the meter side I have a lock nut and grounding bushing. #4 bare from grounding bushing to ground-nutral lug on meter. On panel side, I have always had lock nut and grounding bushing with # 4 bare ground going to ground bar in panel. Bonding screw is installed in panel. Ispector today says that I do not want a grounding bushinh in the panel so as not to have a parellel path. He does want the bonding screw installed though. If the bonding screw is installed don't we still have a dual path? Also, I have the grounds and nutrals seperated in the panel. Thanks for any input or clarification on this topic.
