Saw a potential customer.. he had a sign placed up high on his building.. looks like a regular rectangular sign box with a plastic panel on it with the name of his business.
'Turns out theres no lights in it.. I told him have a sign guy install some fixtures in it and I'll wire it.
He also has at street level across the building and at the entrance a canvas soffit with his business name and info on it. Same thing, I told him to get a sign guy to install some flourescent fixture in it and I'll wire it. There are small 1' square parabolic lenses under for the light to shine threw. (canopy is similar to attainment except it is lettered).
So I figured I'd come here to ask.. I know I would need a switch on the upper metal sign, but if it were just flouresent lights up in the canvas section would that need a service switch also? ALSO if they weren't fluorescent lights installed up in the canopy but rather flood lights on the building pointing down would they need a disconnect switch ?
So I'm reading and I see (for the upper rectangular sign) article 600.3 about the sign needing to be listed..and all the provisions of 600.4... so I'm thinking thats going to put the kabosh on that for this guy...
Then I see by definition electric signs is "electrically illuminated utilization equipment with words and symbols designed to convey information or attract attention."
Is that canopy and electric sign since it has writing on it (as compared to the attached picture which does not)..?
Would then that canopy section would need a disconnect, AND it would also need to be "listed"? If the lights are attached to the structure or to the wall of the building does that make any difference..
Who'd of thunk a couple of lights would get so involved ?
So my question(s) does top sign need to be listed? Is it something that sign guys have the power to do on sight??
Is the canopy a electric sign and needs to have a disconnect switch and adhere to article 600 ? does attaching the fixture to the wall or on the canopy make a difference? Does it need to be "Listed"?
Thank you
Thank you
