NEC Section 600.5(a) disallows any other draw or load attached to either the sign circuit or neutral.
I have a dedicated 20amp circuit that will feed one sign cabinet.
The sign cabinet will be internally illuminated with a 6'x 15mm 6500 neon, powered by a tech 22 electronic transformer.
We also need a total of 9 MR11 20w halogen light fixtures and 2 T12 HO florescent tubes.
Question? Can all of these be run off of the same dedicated 20amp circuit and remain in code and if so will there be any conflict with the different transformers and lighting?
