NEC article 110.16 indicates the need for warning signs on switchboards, panelboards, industrial control panels, and motor control centers but does not indicate the voltage. NEC article 110.33(C)uses the term warning for voltages over 600v; however, the warning sign should read "Danger..."
Q: Should the signal word for voltages between 50 and 600 volts be "Warning..." and 600v and over use "Danger.."? (I am aware of the 4 elements required on the signs. I am simply uncertain about signal word.)
OR, should Danger be use in all instances?
