I responded as a volunteer firefigher to a garage fire. The fire was so intense that there were no light weight ceiling joists left. Investigators said there were multiple starts due to the electrical wiring.
There was a 200 amp panel inside the garage with a 200 amp breaker on the meter panel outside. It had tripped! The investigator said the wiring in the building turned into a giant heater.
Was this a type of grounding issue?
Was this a result from the intense fire burning insulation from the wiring?
The building was stick frame , insulated with fiberglass and sheet rock. Roof metal and siding Hardie cement board.
Any thoughts?????
Fred
Any thoughts?????
Fred
