In our plant there's an air-conditioning unit in one of our substation breaker rooms. The A/C unit runs on 120v, single-phase. On the other side of the room there is a row of 13.8kV circuit breakers.
The question I have is regarding electrical working clearances. I'm aware that the minimum required working distance increases as the voltage increases. Which voltage should I base my clearance distance off of? The 120v or the 13.8kV?
If I base my clearance off of 120v, then the minimum distance needed is 3 feet. If I base my clearance off of 13.8kV (~8kV line-to-neutral), then the minimum distance is 6 feet. Which one should I use?
