Afternoon good folks,
Wondering if anyone might be working in this TN area. My daughter recently moved there, has called 3 electrical companies, but with no calls back.
She needs a new panel installed in her (new) tiny home, just placed there. There is a drop at a pole, and right after the meter on the pole, is a panel with (it seems) 200 Amp disconnect, that then feeds 2 twenty amp breakers. It looks like single phase, 240 V AC, 3 wire, standard type residential. That panel is also screwed to the pole. There is also 2 receptacles fed from the 20 A breakers, screwed to the pole. She'll need a new line pulled from the pole to the house.
Problem also might indicate "lost" neutral. Initially, very high (150) & very low(30) voltages, measured at output of the 20 amp breakers. So, from 1 leg of the (2) hots, at output of breaker to the "neutral" bar. Should of course be 120V. There is nothing plugged in to the 2 receptacles.
Appreciate any help. Hope maybe one of the excellent folks we have here might be in that area.
Thanks very much!
Bill
Thanks very much!
Bill
