redikillowatt
- TX
This is often true - when the only corrosion activity is oxidation. Where both moisture (in higher rainfall areas) & oxygen are plentiful.It's been my observation that the worst corrosion always takes place within the first few inches of the rod entering the soil.
SOME soils have higher corrosive effects on various metals, because of actual mineral composition.
In areas w/ high rainfall & layered soil types (different compositions), there can be one layer a few ft down that stays moist, while layers above & below don't retain moisture well. I've seen this many times digging deeper holes.
I've seen pictures of driven rod electrodes dug up in areas of diff layered soil types, that are almost rusted through, ONLY at one spot, well below ground level. That's likely due to higher corrosive action of that soil layer & possibly higher moisture content in that layer.
In my area, you'd have to dig up the entire rod to know if there was serious corrosion in one or more spots along entire 8 ft length, esp. on older rods. It'd be easier to put in a new rod, once the upper part shows significant corrosion.
Here's a link to a paper listing just some factors of various soils corrosive activity, where corrosion can occur well below ground level.
http://www.csun.edu/~bavarian/Courses/MSE 531/corrosion_class_notes/Corrosion_Chap_11.doc
