electrician
resistance
WA
mar_eps2004 said:
can i have formula of three phase cable sizing
I agree with George,
yet, if you want to find current (I), then one way would be: VA/(Ex1.732)=I
Using (I), you can go to T. 310.16 and find your conductor.
It really does depend on the situation.
Need more details??
electrician
Will the details are as follows,i have T.C.L of 187.5KW to be connected in Three phase 415Volts power supply what will be the size of the breaker may i suppose to use and the size of cable as well,
e
e
I've got T.C.L.187.5KW to be connected a 415 or 230 volts three phase power supply,what will be the size of the breaker may I use and a cable size as well?
