I don't understand why it is in any way more desirable to hook up loads phase to neutral than phase to phase. Why would you want to do that?
Re: the second neutral... seems to me that if it is a neutral, it has to carry current under normal conditions... otherwise it is not a neutral.
I also don't see the reasoning of a separate ground wire in a situation where any current it would ever carry would have to travel through the ground to get there... once it's in the ground the resistance of the earth is zero. It would cause another voltage drop at the ground rod that connects the second "neutral" to the earth. ... unlike the ECG, which is connected to materials that have good conductance .
So any fault current would have to connect to earth, travel through the earth to a ground rod, go back through the ground rod to a conductor that has more resistance than the earth from whence it just came?!? the whole deal doesn't make any sense to me
