Re: Electroflow
Smoke and mirrors. Just the claim it can balance a system is false, so why believe any of the rest of the claims. I have not heard of the system you refered too, but I do not believe it.
First to regulate voltage you would have to use a ferroressonant transformer, tap changing regulator transformer, moter generator, or a UPS to be efective.
Harmonics can be contolled by a ferroresonant transformer, tuned filter, or motor generator.
TVSS is controlled by gas tubes, MOV's, and SAD's
Power factor correction is accomplished by capacitors, but has to be calculated by the changing load conditions. Would require some kind of control and monitor.
Balance the load. Not possible by a black box.
A black box could be designed to to most of the things claimed, but it would be very big, expensive, and custom designed for each application.
An engineer in a box, I doubt it. My guess the thing is a couple of capacitors and MOV installed accross the line, with a line of BS thrown in at no extra charge.
Sorry to be cynical.
[ March 13, 2003, 11:48 PM: Message edited by: dereckbc ]
