mjaco
- Connecticut
I am looking for some opinions on what license will be required to install an Electroluminescent based emergency lighting system. The system operates off 120 and has battery backup. It is a current limited device with a max draw of about 1.5a. It requires 18awg twisted pair wirig and the lamp is mounted in plastic extrusions. All portions are UL Listed but the catch is the lamp material that actualy illuminates also acts as the electrical conductor.The lamps operate at 210vac 600hz. We are being told an E1 or E2 here in CT will be required to do the installation. This could be a significant cost added to the installation which is really no more than hanging a box on the wall, running 18awg wire and lamp material (.025" thick) and connections with wire nuts and the designed lamp connector. I do realize an E1 is required for the main input but to run track and wire seems like overkill.
Can anybody shed some light on this? Thank You
