I understand what sets up the electromagnetic fields. But why does some times a conduit will vibrate when an electric motor starts up ( in this case a A/C compressor) and other conduits not. and is there any why to prevent this? These units are in a church with the conduits running above the ceiling in the auditorium, electrical panels are in mech. room off to side at from and conduits feed over ceiling to units in the rest of building. some of the conduits are pretty loud when a/c unit start and other are quite. units are 208/3ph 5 ton, not sure of the min cir amps or breaker size or wire size. could it be under sized wire? no other problems other than noise at start-up.
