petersonra
- Northern illinois
- Semi-retired engineer
You have to focus on learning things you actually need to know to do your job. Other stuff may be fun and interesting, but fun and interesting has to be a much lower priority than knowledge and skills you actually need. I think the instructor is handling this as kind of a survey course, and that seems to me to be appropriate for a basic electrician type class.100512-2220 EST
How does a straingage transducer work to measure force or torque?
Why would you need to know this? What you need to know is what signal levels to expect for what levels of force. worrying about how that signal is generated is silly. No one except the people that make them ever need to know all that much about this kind of thing, other than in a very general way.
With what voltage levels are you concerned in this application? How does the speed of a permanent magnetic brush type DC motor relate to the applied armature voltage? What methods can you use to measure the current to this motor?
"Black box" kinds of things.
How does an LVDT work? What is the output impedance of an NPN transistor with a collector resistance of 5.6 k ohms?
Stuff you will never use.
Why is aTTL output better?
The answer is that it's not better, it's just different. But it's also not relevant to anything most electricians, or engineers for that matter, will ever deal with.
How does an operational amplifier work and what can you do with it? What is a constant current source and its limitations? How can you make one? In the AC position what does a Simpson 260 meter read? If you measured a sine wave source with the Simpson how would you calculate the power dissipated in a 100 ohm resistor? Now change the source to white noise and the same question? If you suspect the your AC voltmeter is not calibrated correctly, then how can you use a diode and a known good DC meter to check it? And on-and-on.
More stuff no typical electrician would ever use.
If you want to make the leap to instrument technician, then you need more electronics training. In some plants, at least some of the electricians often function as de facto instrument technicians, but you will need more than one class of real basic electronics at that point.
