How fast do electrons flow in a wire . and does the voltage or amps or HZ make a affect the in the speed ?
[FONT=Arial, Helvetica, sans-serif]Electrons can have a wide range of speeds. A slow case: we know that electrons move when there is a current flow in a wire, but the speed at which the electrons themselves move in the wire -- the so-called electron drift velocity -- surprises most people. For example, for a copper wire of radius 1 mm carrying a steady current of 10 amps, the drift velocity is only about 0.024 cm/sec ! [/FONT]
If i remember correctly a little bit slower than the speed of light... which is @ 186,000 miles per second. If memory serves correct the actual speed is @ 140,000 miles per sec. Either way, its faster than you can blink, and faster than you can say "I didn't mean to touch that wire"...![]()
Exactly.Don't confuse the speed of the electron movement with the speed of the effect of the electron movement.
Yes, the speed of light has that effect on most people.In my apprenticeship class we were taught that the effect of electricity was nearly instantaneous. IOW, the difference of the speed of the effect of electricity and instantaneous is almost too small to measure.
Whereas a nanosecond in free space (vacuum) is about one foot.A nanosecond of wire is about 7 inches long.
Very slowly.How fast do electrons flow in a wire . and does the voltage or amps or HZ make a affect the in the speed ?
Very slowly.
About 0.011579414 inches per second for 10A in 2.5mm^2 wire.
Nope. It's faster than that.re: but the effect of opening the spigot is darn near the speed of light
How about just about the speed of sound in water (shock wavefront), nowhere near speed of light.
It's also important for stock trading. Trading computers have a minimum length of CATx cable they must use to make things "fair". "Fair" in that context is a laughable concept to the rest of us. end rantThat is actually important in supercomputer design. One of Cray's super computers was shaped like a vertical cylinder to make the wires shorter.
Thanks.......I like the 'about' followed by 9 decimal places .......
Thanks.......
Sometimes my humour isn't appreciated.
Kirk: What do you think our chances are of getting out of this alive?
Spock: Approximately 1 in 898.9853.
Kirk: Approximately.
Spock: (Lifting one eyebrow) Yes, captain.
