D.T.
- Minneapolis, MN
I am having a hard time figuring out why our titainium heaters in our electroplating tanks are plating up. It's a copper plating line that uses 500 amp, 4 VDC power supplies to each plating tank.
We tried grounding the heater grounds to the rectifier cabinet, but they are still plating up with copper. We are going to try a 4' ground rod this week. Heaters and rectifiers are fed with 480V 3 phase AC current. Conduit on the rectifiers is EMT, using the conduit as ground and the heaters use NM conduit with a ground wire.
