starting to look into a problem at a building when the elevator is running on generator power, the circuit breaker in the elev controller trips. The elev contracto measure a 10% voltage drop at the elev controller and supposedly this happens when the elev is leveling. I do not have excat specifications because I will not be on site till Monday. I have been told the elev is "old" and has not been load tested annualy. I also know the elev is a DC motor and had new SCR controls installed a few years ago and this is when the problems started. Can anybody suggest what I should be looking for and if anybody else has run across this problem.
Thank you
Thank you
