callmestu
- Randolph, Massachusetts
This thread was moved to its own from another slightly related thread:::::::
Hey Guys,
Two things... I was a Journeyman Contractor for four year from 1989 to 1992. The wonderful Commonwealth of Taxachusetts (yes, I am a Masshole) allows Journeymen Electricians to start a business with four important (but not worth mentioning here) restrictions.
My second point is that I am designing an electrical service for a 12 unit condo building and I will have a 120/240 volt single phase, 3 wire service for the dwelling units and most of the house loads. The question comes from the 240 volt delta 3 phase, 3 wire electrical service for the elevator. The reason I found this post if because I believe that my elevator will be 40HP and I believe it will be the only thing on that service.
My question is: What size service do I need to provide? I am expecting between 104 and 120 amps for the elevator, depending on the service factor. My calculations tell me that I should have a 250 volt breaker protecting that motor. Does that mean I need a 250 amp (minimum) service?
[btw: Masshole has officially been added to the Oxford English Dictionary]
Hey Guys,
