Grouch
- New York, NY
is the PV array allowed to be mounted on a steel structure, elevated from the rooftop at a height where people can walk under it? I've seen images of it on a company website, so i'm assuming it is.
So my 3 questions are:
1) I guess it's allowed?
2) aren't there any accessibility requirements? doesn't the array have to be readily accessible or no?
3) NYC, as other jurisdictions i'm sure, has a requirement where you need a 6 foot wide pathway for the fire department on the rooftop. if the array is mounted on a steel structure, can you ignore this 6 foot wide pathway since the array is overhead? Assuming of course the steel structure is not blocking any portion of the rooftop either.
Thanks!
Thanks!
