Article 620.51 - If a hydraulic pump motor is fed directly from an overcurrent device (a molded case circuit breaker) located in MCC (motor
control center) in mechanical room and serving only a single elevator motor, why does 620.51(A) permits a disconnect switch in elevator machine room be a fusible disconnect switch or circuit breaker but not a non-fusible disconnect switch? Isn't the primary purpose of this disconnect switch to assure physical break in the elevator motor circuit?
