storeytime
- Texas
Good day! I have some questions on an elevator I was asked to feed power to. Here are the specs I was given:
25 HP Elevator Motor
Motor nameplate rated current at rated horsepower - 69 amps
Motor locked rotor current for solid state starting - 207 amps
Single phase control load on main supply is 1.3 amps
Motor Code Letter B
They recommend a 100 amp fused disconnect.
My questions:
This facility has 1PH, 240V power. I am installing a phase convertor to get 3 PH power.
1 - From what I have been looking at, I need to protect for 89 amps (69 x 1.25 = 86.25 ---- Motor Code Letter B = 3.54% ----- 86.25 x 3.54% = 89.3 amps)
So, I would protect with a fused disconnect with 100A fuses. (Code recommends a little higher to eliminate nuisance tripping which might trap people in the elevator)
2 -I have to first protect the phase convertor - 100A ?
3 - After the phase convertor, motor controller protection - 100?
4 - They asked for a pit sump pump, GFCI, and lights which have not been roughed in. I can get the GFCI and lights from a circuit in the elevator equipment room. Might need more juice for the sump pump. To get that is there anything that
says I couldn't use a load center with main breaker for the first disconnecting means and feed the phase convertor and sump pump out of that?
Motor Code Letter B
My questions:
