Elevator/Lift on Generator
ASG
Work in NYC
Electrical Engineer, PE
We have a hi-rise office building in NYC that has an emergency generator. They are having trouble renting out the top floor with stairs up to the roof event space so they want to add an elevator that goes from the top floor to the penthouse. Does this elevator that just goes from the top floor to the roof level need to be on the generator?
Your question is a Building Code question.
If your application were using the IBC, according to
Section 403.4.8 - Standby Power, ...Yes, you would
be required to provide standby power for adding an
elevator.
Check the NYC Building Code for this requirement.
