Electromatic
- Virginia
- Master Electrician
I'm wiring a machine room-less elevator whose overall controller nameplate states 65 running amps, 20HP. I believe the conductor ampacity needs to be at least 125% = 81A. I plan on using #4Cu on a 90A breaker. When it comes to the required fused disconnect, it looks like I can go to a maximum of 175% TD fuse = 114A. Is there any reason to size the fuse and breaker in relation to one another? I could still use a 90A or 100A fuse, right?
Also, if it looks like I'm calculating something wrong in general, please let me know.
Thanks as always
Thanks as always
