Steeno
New member
- Appleton WI
I'm tasked with wiring a supervisory circuit for a shunt trip to an elevator controller.
I have a 120v circuit for my shunt trip.
I need to wire this thru the elevator disconnect interlock contacts...and to the controller. The idea is the controller wants to know if the disconnect is turned off....the shunt is activated...or that 120v loses power ie breaker is off or loses power.
The shunt is activated by a relay on my fire alarm system activated by the heat detector in the machine room.
Any idea how to wire that circuit thru? I figure the contacts on the controller is simply wired in series thru the circuit...then to the controller. Not sure how to wire it up at the shunt / power source level tho.
