Google (image) is your friend!
Here is an over view of most the the "Shunt"'s available. I beleive an elevator shunt is a dual element with remote shutdown. the remote is controled via a Fire alarm IE it breaks the voltage coil, or the sensing coil (F/A)
releases the current sensing coil...
I believe the shunt
applies current to activate the coil. The weakness here is that if your current source is kaput, so is your shunt.
in the past 30 or 40 years elevators have incorporated devices intended to try to keep people from being cooked alive in the event of a fire. in a modern elevator, once a fa is in alarm, power is shut off (usually via a shunt trip mechanism) and the elevator is sent to a place where passengers can hopefully disembark safely, and only the fireman can use the elevator.
More typically, if one of the
elevator lobby smoke detectors or the shaft smoke detector goes into alarm, the elevator car will return to the primary recall floor, unless the smoke detector in alarm is in the primary recall lobby, in which case the car is directed to the alternate recall floor.
Fire fighters can use the firefighters key to then overide the recall and operate the car.
The shunt trip is employed if the elevator shaft is sprinklered. In this case, a heat detector is mounted within 24" of the sprinkler and is selected to activate below the operating temperature of the sprinkler. When the heat detector is activated, the shunt cuts power to the elevator
immediately, stopping the car
wherever it is, potentially turning "New York's bravest", for example into "New York's crispiest". This is the way most codes are written. I have heard rumors of jurisdictions allowing immediate recall to the egress floor before the power drops out, but I haven't seen it myself.
