In the summer there was a building that had one of their elevator shut down. The voltage read 190 volts but you need 208 volts (3-phase) in order to operate. Everything is good now but they are worried it might happen again as summer approaches. The guy claims it's because Con-Edison was lowering the voltage in the summer to reduce peak demand.
My solution I don't know if this will work:
Can I use a Power Conditioner/Electronic Voltage Regulator that stabilizes the voltage to 208V? Something like this maybe?:
https://www.larsonelectronics.com/p...egulator-208v-3ph-input-output-voltage-nema-1
I am hesitant with this because I don't really know why it dropped to 190 volts in the first place. What could be the reason? What if it's something simple?
