mwm1752
- Aspen, Colo
With the elimination of 406.15 section 404.14 seem to govern this issue;
404.14 Rating and Use of Switches. Switches shall be used within their ratings and as indicated in 404.14(A) through (F).
(E) Dimmer Switches. General-use dimmer switches shall be used only to control permanently installed incandescent luminaires unless listed for the control of other loads and installed accordingly.
Can some one describe a non-general use dimmer?
Does this now state residential use receptacles are compliant with code when controlled by dimming modules associated with a lighting control system?
