housemoney
- Midwest
- Mech Engr
I have an industrial control panel furnished by a vendor we're installing, which powers a handful of small process motors (all on their own circuit) in the same room (within sight).
The owner doesn't require local disconnects for maintenance, and is fine with disconnecting all loads with the control panel's main externally operable disconnect together.
New local inspector said NEC 430.112 is "only for motors on the same circuit", and each motor in this room will also need it's own local disconnect.. is this accurate?
