You use this device if you are using a sensor with dimming capabilities to dim the lights on normal use, you notice what trig the EM relay is when you don't have 0-10V from the switch (when it loose normal power). The emergency power is coming from a different source (Generator or Backup power system) if you connect the back power feed to the same circuit it won't work because there is not power on the circuit itself. You need a different source for the EM circuit, that will have power at all time. If you don't have a separate backup power you shouldn't use this device.
