Designer69
The emerg. egress lights (powered by emerg. generator pnl) need to be on a separate switch from the normal lights in the area right?
Then a control relay above the emerg. lighting switch overrides that switch position on loss of power.
Just want to make sure that nowadays you don't put the emerg. egress lights on the same switch as the normal lights and somehow still override the emerg. lights (switch position) on loss of power?
Thank You
Thank You
