sparky1118
- Massachusetts
- Master Electrician
Question I am doing a service change. We are on the 2020 code. I have my emergency disco outside for the fire department and inside I have my electrical panel with main breaker. So I’m only using the outside disco for emergency purposes only. My question is since the panel is a main breaker panel. Does my water bond and ground rod conductor need to go outside or stay at the main panel? I figure since the outside disco is only for emergency purposes only and I still have a main panel it should go to the main panel. What do you all think?
Sent from my iPhone using Tapatalk Pro
