Emergency Disconnect for 1 or 2 family dwelling
Grouch
New York, NY
The 2020 NEC introduced the emergency disconnect for a 1 or 2 family household in section 230.85. The NYC amendments added an exception to that section, stating the following:
Section 230.85 – Add an Exception at the end of Section 230.85 to read as follows:
Exception: If the emergency disconnecting means cannot be located in a readily accessible outdoor location, or if the utility metering equipment is located indoors, 1 of the following disconnecting means shall be permitted:
1. A remote disconnecting means provided by the utility
2. An indoor shunt-trip disconnecting means with the control device located in a readily accessible outdoor location and marked, “Remote Emergency Disconnect”
3. An approved equivalent means
My question is regarding #2, with the shunt-trip. How do you power the control device located outside, that controls the indoor shunt-trip breaker? Do I bring 120 volts to the control device by tapping off one of the hot wires of the service entrance conductors? It would seem strange to bring 120 volts from a panel inside the house, since that panel would be on the load side of the shunt trip emergency disconnect and service equipment.
I would power the shunt trip off one of the branch circuit breakers in the indoor panel. There is no way I would use unprotected service conductors.
It's just strange. You hit the shunt trip, and you would immediately lose power to that shunt trip. It doesn't matter I guess, since at that point power is disconnected from the dwelling anyway.
If the shunt trip coil is not rated to be continuously powered, and if the breaker doesn't have an internal mechanism to disconnect the coil when off, then the above behavior is a necessary feature to avoid burning up the shunt trip coil.
I have no idea if most/all shunt trip breakers have such an internal mechanism, just that the couple I have installed state in their documentation they do, so I didn't have to worry about the issue.
Cheers, Wayne
You have to manually reset the breaker so no need for any power to the button have you have activated the shunt trip,
Other shunt trip applications often do receive shunt coil voltage from the same circuit that is being interrupted. This method also assures you don't leave the shunt coil energized after closing the switch that actuates the shunt coil. Which can prevent burning out the shunt coil if it is a type not intended for long term energization, which some might be.
I wouldn't want to tap the service conductors even if you put an overcurrent device near the tap, would still leave you with that control circuit within the building still energized, part of the idea is you are supposedly de-energizing all the wiring in the building when you operate that emergency disconnect switch.
I have a follow-up question: say you have a 2 family dwelling, such as a townhouse. You also have a separate meter and panel for the house loads. Do the house loads also need this emergency disconnect? Or only the dwelling units? I assume it's only the dwelling units.
No I think the whole service falls under the EM disconnect rule if the building is a two family dwelling. 230.85 is a bit vauge, but 'two family dwelling' refers to the building, not the dwelling units directly.
Ah. So I would need 3 emergency disconnects. One for each dwelling unit (two) and one for the house loads.
I'm not sure that's exactly right. The wording from 2020 is "For one- and two-family dwelling units, all service conductors shall terminate in..." And a dwelling UNIT refers to each individual unit, not the building according to Article 100.
I suspect this was a mistake since they removed the term "unit" in 2026, and a quick search through 2020 didn't find the term "two-family dwelling unit" anywhere else.
However wouldn't you be required to locate all the service disconnects together anyway per 230.72? If the house loads are in a panel next to the meters anyway, then you can just stick an "emergency disconnect" label on that panel
Rob G
Seattle
Yes clearly a mistake as a two-family dwelling unit is not a thing and the definitions are clear. Requirements or permissions for "one and two family dwellings" appear in various places in the code (e.g. 334.10, 690.12(C), 706.15 ...) and that is the most reasonable interpretation. The alternative interpretation would require "For dwelling units of one- and two-family dwellings ... ". (And what would be the logic behind exempting common areas from the rule? Do energized conductors in common areas present less of a problem for first responders?)
However wouldn't you be required to locate all the service disconnects together anyway per 230.72? ...
Yes but they could be inside. The point of the EM disconnect rule is they must be outside. Also if you read upthread the OP is asking about a shunt trip so it's a somewhat special situation.
Does such a building qualify as a "two family dwelling"? With that "house panel". Art 100 definition says "a building that consists solely of two dwelling units" where does the house panel fit in with this?
Most "two family dwellings" I can recall never had any "common areas" or "house loads" and were basically two dwellings with a common wall between them but otherwise were pretty much separate in just about all other ways.
