mtnelectrical
- Essex, New Jersey
Does anyone does inspection /certification of exit emergency lights with back up batteries? Any special procedures to test the batteries? Any special form to filled for the customer?
He didn't say "tap". The monthly test is only 30 seconds.
My area the fire marshal checks them.
My area the fire marshal checks them. To test battery just turn off breaker or push test button. I assume they leave some sort of acceptance paperwork.
Same here; perhaps it is state wide. I wanna say the fine is $500 per bad fixture. Actually kinda surprised the fire marshalls dont write these up all the time, given the safety aspect, how much they could make on fines, and how easy it is for a business to comply.
Last job where I changed out signs, there were 8 or 9 "bad" ones. Come to find out the original installer, who put them in years ago, never removed the plastic shipping insert on the batteries, so they never worked. After making a comment about what a sloppy job that was, I also found the original installer was the company I was working for. Oops.
I would think any place with its own maintenance would check exit signs and e-lights monthly; I know we did when I worked hotel maintenance.
Could the yearly testing be done with an unplanned power outage? I know you wouldnt plan it that way, but if you lose power, may as well, right?
That is the time I get the most requests to repair them - they failed when needed, usually just need batteries and get called a few years later when they fail happen to fail when needed again.Could the yearly testing be done with an unplanned power outage? I know you wouldnt plan it that way, but if you lose power, may as well, right?
