Ravenvalor
- Triad region of NC
- Electrician
Hello,
I have a customer who has 19 - Cooper Lighting emergency lights model# CC-8 that use 12-volt, 18aH batteries. Should the output voltage from the emergency light to the battery under 'power on' conditions be 13-volts or higher? Can I measure the voltage with the batteries connected to the light? I called the manufacturer's technical support and the person that I spoke with seemed to indicate that the voltage probably should be at least 13-volts and that it was okay to test the voltage with the battery connected.
I normally do not spend any time testing emergency light output voltage but these particular ones look expensive.
Thanks,,,
Thanks,,,
