I'm working on a Data Center project, The whole building will be backed up by an emergency generators. I determined that I will need 150KVA Inverter System for emergency lighting. My questions are:
1. Does anyone one makes 150KVA UL 924 listed inverter system? so far, the biggest I have seen is 80KVA.
2. Do I really need 90 Minuits battery back up time since the whole building is backed up by the emergency generators? someone have told me that since the building backed up by generators you could use 20 Minuits battery back up time (not sure where this exception came from!).
Thanks you,
Thanks you,
