electricblue
- Largo, Florida
- EC
I know this probably is not a NEC. Anyone point me to the code for exit light placement and emergency lighting requirements ?
It's in the IBC the rule is 1 foot candle at the floor for the entire path of travel to the exterior of the building. Emergency exterior egress lighting is required if you are required to have two or more exits and if only two exits are required and they put in four exterior doors, you would get one at each door.
Exit signs get a little tricky, a lit exit sign isn't even required until the occupancy is more than 49 and are required to be seen from where ever you are in the building. That's the part that get's tricky. If you are in a place with a lot of tall shelves like a book store or a big orange, should you put one at the end of every aisle? And is a door to the exterior really an exit? It used to not be so, but the code now says that every door leading to the exterior is an exit. Many things you have to remember too such as you can't exit through a warehouse and you can only exit through one ajoining room, etc.
Always check with the building dept or in some cases the fire department to see what they're really going to want.
I think most places assume a customer can reasonably make it to the end of the aisle into the "racetrack". When I've done layouts with a similar situation I assume they can make it out of the aisle and I've never had an issue.
What about doors which are just there for delivery? If a door is defined as an egress door, all sorts of ADA guidelines come into play. And would you need to point public patrons in the direction of a door to the exterior in a non-public area? For example, a door in a commercial kitchen meant for deliveries (but the kitchen has 2 other exit paths out of it). Would there need to be an exit sign above this door? Would customers need to be directed through a potentially hazardous kitchen now that the door might be the closest egress door? I know this is all off topic, but it got me thinking.
