For emergency lighting circuits fed from an an emergency panel and controlled through occupancy sensor, do these circuits require an a bypass relay?
For instance, if an entire floor of a commercial building uses occupancy sensors, there are going to be emergency lighting fixtures that will be turned off by occupancy sensors (unless the lights are specified as night lights). When the power is switched from normal power to generator power, all the occupancy sensors will be reset on the floor and, if they don't sense occupancy in their spaces, the lights specified as emergency lights won't turn on. Unless there was a bypass relay. Which will turn on ALL emergency lights regardless of occupancy.
