jmsbrush
- Central Florida
I can not find this in the NEC. Are you required to have emergency lights in patients room in a Dr. Office?
If this is true, I need to find the reference. Thank you.
My rule of thumb with emergency lights is basically this; if the PUBLIC can access the room, or regularly goes in the room, then you should put an emergency light. I have always put emergency lights in exam rooms etc. If the lights go out, people usually want to put their clothes on prior to leaving, same idea with restrooms.
So a patient room in my opinion would have to have one, a doctors office wouldn't if it is the actual office where the doctor is working.
Yea, I wasn't referring to a required backup lighting system.
I was talking about a fixture that is tied into the local lighting system that stays on when the power goes out for a minimum of 90 minutes. This could be the wall back eye-ball lights, or a fixture with a battery ballast.
