jakeparsons03
- USA
- Engineer
We are starting to look into placing e-stops for different kinds of machinery throughout a new chemical plant (all green space as of today). My main goal is to make sure that their plan (whatever that may be) is code compliant. I have a few questions to clarify from the research I have done.
1. From what I read E-Stop locations must be determined by an accredited risk analysis. Is this right?
2. When I have put in E-stops in the past I have wired them in line with the starter command signal. Category 0 E-stops are required to physically remove power from the system. Technically, removing power from the starter opens the relay on the motor causing power to be physically removed. Is that considered a Cat-0 Stop?
