HighWirey said:
Was your firm responsible for the complete install, or just the electrical part? If you are responsible for the complete install, did you not submit shop drawings showing all those 'devils details' for approval, prior to proceeding with construction. Asking for actual code requirements at this time sounds like it is too late.
There used to be a song in bygone days "What Lola wants, Lola gets". Here Lola = the AHJ. I'll bet Lola likes 10 feet better than 8 feet . . .
Best Wishes Everyone
This thread is one of the best reasons I joined this forum. As an AHJ inspector I learn a lot from these stories. I am truly amazed at what I see in the field and in here, how many inspectors are still calling it from memory, not using actual sections for their citations, and not keeping up on the code changes. Many are truly well meaning, but behind the times, but some are just plain wrong. While I am never going to inspect at 100%, I try to get closer each time.
I hope that someone will respectfully challenge me when they disagree. I might be wrong, not see it their way, or can use their professional experience to better understand. There are limited situations in the CT codes that allow me to be "Lola", otherwise, it's straight out of the book.
As for the "pre-approved" plans, while it's very true that I try to catch it all in plan review, please see the 100% comment above. In CT, probably elsewhere, it is still incumbent upon that Owner/landlord/contractor to install in a compliant fashion, weather I catch it in plan review or not.
Ask the inspector for the citation on the 10' so you can "do it right this time" (makes him or her happy), then you can also see what is being cited and if it's legit.
Mike
