smjjpres
- Dallas, Texas
Does anybody have a recommendation for an electrician in Dallas, Texas that could fix wiring problems causing EMF?
It would have to be a lot of money. Traffic in KC was bad enough today.
Doesn't the OP question violate forum rules? OP profile indicates he is not an electrical professional, so we can't give him any advice except to find a professional. He apparently is looking for a professional, but this site is not Craigslist or similar either.
He is not asking for a how to and he is not a diy. I see no reason not to direct him to a licensed individual.
Don't be too sure when I got into this I was the only one around who knew what to do to fix the problems. I have had people from other cities call me to help them understand it.Stop at the local supply house & one will show up. Google, craigslist, Yellow Pages.
For the right amount of money I'll work in Dallas.
I agree, surely there is someone in that area that knows at least a bit about EMF and how to correct wiring problems associated with them. I would have to do a bit of reading again... it was the "problem of the month" a few years ago.
ME said:Common Causes of EMF
1. If the EGC is touching the grounded conductor after the OCPD.
2. If the grounded conductor from two different circuits are connected together after the Ocpd. I see this in 2 or 3 gang switches where either the neutrals get crossed or they are all tied together.
3. If the circuit conductor are not run together as in K&T wiring or sometimes you see this in 3 way switches where the EC runs 2 wire cable between the 3 ways and picks up a neutral at one box and the feed at the other.
