I have a client in Ottawa that owns two large 250 suite apartment buildings with a poorly installed concrete slab electric heating systems. These buildings are 25 years old and suffer from excessive EMF in many areas of the building causing TV and computer problems.
The heating cables are unusual in that they are continuous over an entire floor-plate of the building and draw about 50 amps at 600 volts. Usually we see these systems installed on a "suite-by suite" basis with cables zoned for each suite.
Recently, we have installed SCR controls on the heating cables to provide improved control but this has not improved the EMF problem...(I don't think it has made it any worse either - even with the increased harmonics)
We are looking for an inexpensive way to measure the EMF field (in order to move TV's, etc.) and/or other solutions. Will it work if we put a piece of thin steel on the floor (under a TV) with a wire to ground?
Any help on this issue would be appreciated.
Regards,
James H. Mann, P. Eng.
Consulting Engineer
Mann Engineering Ltd.
james@mannengineering.com
www.mannengineering.com
(416) 201 9109 office
(416) 201 9122 fax
Regards,
Consulting Engineer
(416) 201 9122 fax
