EMF in my house
rockban
New member
I am using a meganetic field meter(Trimeter) to measure the EMF in my house.
There is a pipe in the crawl space which is measured to be 25mG if I put the meter on it. It is 8mG one foot away. Let me call it pipe #1. The pipe #1 is small and is connected from Garage to swimming pool pump. It goes underground in the yard. I guess there are electricity wires inside the pipe because there is a box connected it which is supposed to be a wire box. Unfortunately, the pipe is just below two bedrooms. So the EMF readings in the two bedroom are about 3mG in many spaces.
So I decide to fix the problem. however, when I turn off the main power at the panel, the EMF reading of the pipe is not changed at all. I am sure the power to the house is cut off because the reading on PG&E(the utility vendor) meter is 0W. I also measured another pipe under the PG&E meter. let me call it pipe #2. It is 50mG if I put meter on it. The pipe #2 is supposed to carry electricity wires from street to the house. There is a small strand connecting the panel to the pipe. I guess the strand is a ground wire.
I measured the waterpipes in bathrooms. there is no big readings as pipe #1.
I need some help now.
1 After I turn off the panel, it is supposed that both pipe #1 and #2 to be 0 current on ground wire and other wires. So the EMF reading should be much less around the pipes. Is my understanding correct?
2 As I can still observe EMF on the pipes, I guess there is ground current on the pipes. Is there any other possibilities to have the same phenomena?
3 Is it useful if I add more ground electrodes in garage and crawl space and connect the pipe #1 to these ground electrodes?
4 Should I buy clamp meter to measure the current? I think the EMF meter has the same work function as clamp meter. so is it necessary?
thanks ahead
iwire
Massachusetts
I am closing this thread, in accordance with the Forum rules. This Forum is intended to assist professional electricians, inspectors, engineers, and other members of the electrical industry in the performance of their job-related tasks. However, if you are not an electrician or an electrical contractor, then we are not permitted to help you perform your own electrical installation work.
