hbiss
EC, Westchester, New York NEC: 2014
- Hawthorne, New York NEC: 2014
- EC
Scratching my head here. Customer is a drug store. About a year ago a transformer blew someplace in the area which caused damage to quite a few businesses. For this customer we had to replace their small PBX and they had to replace their automated refill system. All was fine for about 6 months when customer complained that they couldn't use any credit card terminals. They use a line share device which simply takes two phone lines and connects them to four credit card terminals as the lines are needed. This has always worked well since no more than two terminals are ever in use at any one time but now it seemed that all were in use at once. Investigation revealed that one credit card terminal was removed (unplugged from the jack) and none of the other three were in use yet the LEDs on the line share device indicated that all four were in use. What was strange was that disconnecting the run that went to the jack for the terminal that was removed returned everything to normal. I suspected a damaged cable but resistance between conductors and to ground of the 20' of CAT3 wire were normal. 20 feet of wire with nothing at the other end. All wiring is visible.
Now the latest problem is hum in the phones and the automated refill system which is connected off the analog PBX. Swapped out the PBX to no avail. Right off the PBX= no hum. Add 30' of wire=hum. This system and wiring has been in place with no problems since 2001.
I'm suspecting an electrical problem and I haven't looked at the service yet. Am I right in thinking a neutral problem someplace, either the customer or the utility?
-Hal
-Hal
