electricalperson
- massachusetts
i went to my panel in my house and i had a very high EMF reading on my gaussmeter. the panel is a 100 amp 120/240 volt challenger main panel.
the service is grounded only at the water pipe inside. the water pipe coming into the house is copper and its all grounded properly and i dont have ground rods.
i measured current on phase A and B i had 0.5 amps on one phase and 5 on the other. i had a ~4.2 amps on the neutral and .3 on the GEC.
i believe all is normal and the EMF's are coming from the net current produced by unbalanced neutral current because some of it is going down the water pipe.
am i correct with this? just trying to see if i understand everything properly
